[postgis-devel] Spatial relationships not defined should return null
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Feb 10 03:05:32 PST 2012
On 10/02/12 04:53, Paul Ramsey wrote:
> I'm not enthusiastic to change this behavior.
> P.
> On Thu, Feb 9, 2012 at 2:39 PM, Jose Carlos Martinez Llario
> <jomarlla at cgf.upv.es>  wrote:
>> Hi list,
>> According to the standards the spatial predicates which are not defined as
>> st_touches (point , point) or st_overlaps (line, polygon) must return null.
>> PostGIS returns false in those cases (trunk and previous versions too), so
>> it is against SQL/MM.
>> Should I open a ticket or this is the wanted behavior?
>> Regards,
>> Jose
I agree with Paul, it does sound a little strange. Can you point us
towards the relevant page in SQL/MM? Also what do SQL Server/Oracle
Spatial do?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
