[postgis-devel] Regression performance.
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Feb 10 06:38:42 PST 2012
It is true that passing the x and y might be usefull in some cases but it is kind of a luxury.
If I can give my two cents I would suggest:
-we come back to the float so we don't penalize most applications. I guess the only penalty to the one using the x and y is to cast the float to integer in the expression. Right?
-we fill a ticket expecting some input from PostgreSQL people (robe or a some inquiry on their list)
-we fix/wontfix the ticket depending on the info we get.
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of dustymugs
> Sent: Thursday, February 09, 2012 7:32 PM
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] Regression performance.
> Well, please do come to a consensus. Once that is achieved, I'll make any
> changes that need to be made to the 2-raster variants.
> -bborie
> On 02/09/2012 04:14 PM, David Zwarg wrote:
> > I see your point about #1557, but I disagree.
> > I believe that we should aim for the best performance out of the
> > raster MapAlgebra routines in any way possible. It may be inconvenient
> > for calling functions, but if you really need those values, you may
> > always do "[rast.x]::integer". It is a little messier, but I believe
> > that it's an acceptable inconvenience: no data is lost converting the
> > raster x or y coordinate from float8 to int32, and only if you need it
> > will you incur the penalty of casting to an integer.
> > Unfortunately, that is exactly the situation you seem to be
> > experiencing, strk, but I believe that it would be a mistake to
> > penalize all callers of ST_MapAlgebraExpr for this overhead, versus
> > the rare (we *just* introduced the x& y parameters) case when you
> > need the x and y parameters inside of the cell processing expression.
> > A note on the surprising factor: it took myself and David Bronough at
> > the code sprint all day to profile and identify what was happening.
> > Both of us were looking at the patch from r9112, scratching our heads.
> > The removal of strstr should have made it faster, but it turns out the
> > use of integers in the expressions were doing something in the
> > parser/planner/evaluator for every pixel, and this was slowing
> > everything down. It doesn't make sense on many levels, and I would
> > have thought that integer math would be faster that floating point
> > math, but in this case it is not the case. Something in the way
> > postgres evaluates that parameterized query changes that assumption, which I
> have no knowledge of (thus the mystery for me).
> > Thanks,
> > Zwarg
> > On Thu, Feb 9, 2012 at 12:47 PM, Sandro Santilli<strk at keybit.net> wrote:
> >> On Thu, Feb 09, 2012 at 12:20:45PM -0800, David Zwarg wrote:
> >>> Hello,
> >>> I was profiling the performance of the changes that happened in
> >>> r9112,
> >> and
> >>> it turned out to be very significant to pass and evaluate integers
> >>> in the prepared expression. Sticking with float8 values for the x
> >>> and y
> >> positions
> >>> of the pixel contain significant performance benefits (although
> >>> counter-intuitive).
> >>> I've changed the x and y positions in 1 raster map algebra back to
> >>> float values for performance reasons.
> >>> These are my metrics for running 5 sets of 10 rasters, each 500x500
> >> pixels,
> >>> from one of the SRTM tiles linked to by the WKTRaster tutorial page.
> >> Times
> >>> are in milliseconds. The first column is revision 9112 (removal of
> >>> strstr in the pixel loop, using integer as x and y pixel values),
> >>> the second column is that same revision (with a modification to use
> >>> float8 instead
> >> of
> >>> int32 for x and y pixel coordinates), the third column is revision
> >>> 9111 (using strstr in the pixel loop), the fourth column is the
> >>> incorporation
> >> of
> >>> this change into the HEAD revision as of this morning (more memory
> >>> allocations have been moved out of the pixel loop).
> >> The numbers for those like me not willing to fire a graphical browser:
> >> r9112 r9112-int r9111 r9137
> >> 9839.746 8473.403 9094.589 7820.646
> >> 6228.067 5329.813 5763.88 4738.372
> >> 8749.516 7441.936 7893.893 6866.745
> >> 13618.762 11254.392 12177.314 10780.401
> >> 6233.851 5442.746 5730.231 4767.192
> >> I'm really surprised. Which version of PostgreSQL were you using ?
> >> I'm still not convinced we should pretend numbers are float though.
> >> It was changed back for a reason:
> >> http://trac.osgeo.org/postgis/ticket/1557
> >> --strk;
> >> ,------o-.
> >> | __/ | Delivering high quality PostGIS 2.0 !
> >> | / 2.0 | http://strk.keybit.net
> >> `-o------'
> >> _______________________________________________
> >> postgis-devel mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
