[postgis-devel] [PostGIS] #1567: [raster] The SRID of the empty raster returned by ST_MapAlgebraExpr(rast, rast, 'intersection') should be 0
trac at osgeo.org
Fri Feb 10 14:00:26 PST 2012
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Replying to [comment:2 pracine]:
> Hum. It might make sense.
> Does it make sense to give a SRID to en empty raster?
In this situation, I'd say yes since the output is based upon the input
rasters.
> Do empty geometries have a SRID?
No. The following returns NULL
SELECT ST_SRID(NULL::geometry(POINT, 4326))
> Is it normal to be able to create and empty raster with SRID equal to
-1? Should not SRID be clamped to 0?
SRID < 0 is clamped to 0.
So, change the empty raster's SRID to zero?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1567#comment:3>
