[postgis-devel] [PostGIS] #1567: [raster] The SRID of the empty raster returned by ST_MapAlgebraExpr(rast, rast, 'intersection') should be 0
PostGIS trac at osgeo.org
Fri Feb 10 14:12:18 PST 2012
  Reporter:  pracine  |       Owner:  pracine
      Type:  defect   |      Status:  closed
  Priority:  low      |   Milestone:  PostGIS 2.0.0
 Component:  raster   |     Version:  trunk
Resolution:  invalid  |    Keywords:
Changes (by pracine):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 As a last test I would check the SRID of the empty geometry resulting from
 an intersection. If it's the same as the input geometry then no. If it's 0
 then yes.
 SELECT ST_SRID(ST_Intersection(ST_Buffer(ST_SetSRID(ST_MakePoint(1.5,
 -1.5), 4269), 0.2), ST_Buffer(ST_SetSRID(ST_MakePoint(4.5, -1.5), 4269),
 0.2)));
 Gives 4269... so it should be the same as the input raster...
 I set it to invalid.
 However:
 SELECT ST_SRID(ST_MakeEmptyRaster(4, 4, 0, 0, 1, -1, 0, 0, -10))
 should return 0 no? Since:
 SELECT ST_SRID(ST_SetSRID(ST_MakePoint(4.5, -1.5), -4269));
 Does...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1567#comment:4>
