[postgis-devel] [PostGIS] #1575: Configured without raster still tries to make raster/rt_pg/rtpostgis.sql
PostGIS trac at osgeo.org
Mon Feb 13 11:48:06 PST 2012
 Reporter:  chmelarp               |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 after:
 $ ./configure --without-topology --without-raster && make
 I get these ...
 /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis.xml >
 raster_comments.sql
 /usr/bin/xsltproc ./xsl/topology_comments.sql.xsl postgis.xml >
 /usr/bin/xsltproc ./xsl/tiger_geocoder_comments.sql.xsl postgis.xml >
 make[3]: Leaving directory `//////postgis-2.0.0alpha5SVN/doc'
 cp ../../doc/postgis_comments.sql sql_bits/postgis_comments.sql
 make[2]: *** No rule to make target `../../raster/rt_pg/rtpostgis.sql',
 needed by `sql_bits/rtpostgis.sql'.  Stop.
 make[2]: Leaving directory
 `//////postgis-2.0.0alpha5SVN/extensions/postgis'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1575>
