[postgis-devel] [PostGIS] #1575: Configured without raster still tries to make raster/rt_pg/rtpostgis.sql
trac at osgeo.org
Mon Feb 13 13:25:01 PST 2012
Reporter: chmelarp | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: 2.0.x
Keywords: |
Comment(by robe):
The issue it looks like is that its trying to make the extensions probably
becasue running 9.1.
I think the best thing to do is to not allow building extensions if raster
and topology are disabled.
We can't have two versions of postgis extensions one with raster and one
without because its really not the same extension.
If just topology is disabled I suppose we can disable the topology
extension building.
Paul -- can you make this change. Not sure how to since I don't know how
it plays with the whole configure script.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1575#comment:1>
