[postgis-devel] Looking for a good ST_ChangeEdgeGeom semantic
Andrea Peri aperi2007 at gmail.com
Thu Feb 16 11:48:38 PST 2012
Perhaps an acceptable simplification should be
allow a edge change that don't change the
id of leftface and rightface as available on the edges.
This mean to allow a change of edge geometry only if the result is always
between the same two faces.
This mean also that it could move to another set of start/end nodes but
only if always inside the same two faces.
But see-ing the iso specs is no really clear to me if the start-node and
the end_node  must be always the same or can change.
So for example:
If the starting situation was this:  (were 'o' are node not vertex)
    o--------------o
    o------E1------o
    o              o
    o--------------o
this other should be allowed with a ST_ChangeEdgeGeom ?
    o--------------o
    o              o
    o-----E1-------o
    o--------------o
It will leave the same two faces for the edge E1.
or not?
I guess no.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120216/f06eee26/attachment.html>
