[postgis-devel] Looking for a good ST_ChangeEdgeGeom semantic
Sandro Santilli
strk at keybit.net
Fri Feb 17 08:20:58 PST 2012
On Fri, Feb 17, 2012 at 07:21:13AM -0800, Paul Ramsey wrote:
> I think your concept works fine in my head. I worry that it might be
> brittle in practice since so many of these changes will be very minor
> single vertex shifts leading to test polygons that are very thin and
> narrow, precisely the thing that leads to topology failures in GEOS.
> However I don't let have a similar concept as easy to explain.
True, construction of the "motion range polygon" is the weak part.
But I'm still concerned about conceptual correctness.
> Also note you'll have to do more than just join up the edges due to
> the ease of constructing an invalid polygon that way (morph a straight
> line into an "S" shape, you get the classic invalid figure eight
> polygon).
Yup, first version used ST_MakeValid and ST_CollectionExtract, but
got to a failure with closed edges, forming rings on their own and
apparently breaking the nice even/odd picture. New version adds
a straight line between end node and start node, builds 2 rings
(using the rings that the old and the new edges form with the straight
line) and then uses their symdifference as the "motion range".
I still have to deal with other constraints, like a butterfly wing
becoming an hole in the other wing...
--strk;
> P.
> On Fri, Feb 17, 2012 at 12:30 AM, Sandro Santilli <strk at keybit.net> wrote:
> > Great, thanks a lot Paul.
> > I've slept over it and internalized that as well.
> > And "Homeorpheus" came to the rescue !
> > I woke up and while explaining the problem of "figuring out when
> > the restriction is violated" to my daughter I got enlightened by
> > this simple algorithm:
> > If the polygon formed by the _old_ and the _new_ edge
> > contains any node, then the rule is violated.
> > It seems to work pretty well. Only corner case is the closed edge
> > being reverted, but a single corner case I can live with :D
> > So, for your delectation, and hoping your mail client uses monospace
> > fonts, here are the cases I've shown with the algorithm applied:
> > Source:
> > o========o
> > o
> > Targets:
> > o========o
> > | o | NOT VALID (a node inside)
> > o==,-----o
> > | | o VALID
> > o==,-----o
> > | | o .-. VALID
> > o==,-----o | |
> > | | o | | VALID
> > Exciting !
> > --strk;
> > On Thu, Feb 16, 2012 at 10:07:10AM -0800, Paul Ramsey wrote:
> >> The two odd cases you show are impossible without "lifting" the edge
> >> up off the paper and putting it down on the other side of the other
> >> edges. The deformation has to be done without leaving the manifold.
> >> The authors perhaps assumed the reader would internalize that
> >> restriction.
> >> P.
> >> On Thu, Feb 16, 2012 at 10:02 AM, Sandro Santilli <strk at keybit.net> wrote:
> >> > Someone might have been following the ST_ChangeEdgeGeom saga:
> >> > http://trac.osgeo.org/postgis/ticket/1571
> >> > The problem is that ISO/SQL-MM specification don't tell
> >> > much about what's allowed and what not when it comes to
> >> > changing the geometry of an edge, except that its endpoints
> >> > must remain the same. So for example you can go from this:
> >> > o--------------o
> >> > To this:
> >> > o---, .---o
> >> > Now my problem is, how far can we push this ?
> >> > Should we also allow going from this:
> >> > o--------------o
> >> > o------E1------o
> >> > o--------------o
> >> > To this:
> >> > .--------E1--------,
> >> > | o--------------o |
> >> > '-o o-'
> >> > o--------------o
> >> > And what about from this:
> >> > o------E1------o
> >> > To this:
> >> > '-o o-'
> >> > I tend to think "NO", but I don't have a clear definition about it.
> >> > It may have to do with considering the edge as made with
> >> > an elastic matter, taking it with your hand and morphing it
> >> > into the new position w/out hitting obstacles. And I think I've
> >> > read about this kind of concept somewhere, related to topology.
> >> > Does anyone have better nomenclature for the concept ?
> >> > --strk;
> >> > ,------o-.
> >> > | __/ | Delivering high quality PostGIS 2.0 !
> >> > | / 2.0 | http://strk.keybit.net
> >> > `-o------'
> >> > _______________________________________________
> >> > postgis-devel mailing list
> >> > postgis-devel at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> > ,------o-.
> > `-o------'
,------o-.
`-o------'
