[postgis-devel] ERROR: SQL/MM Spatial exception - geometry crosses an edge
Salvatore Larosa-1 s_larosa at libero.it
Wed Feb 29 12:35:27 PST 2012
Hi Sandro,
If I try using a simple polygonal geometry (only 2 polygon with a handful of
vertices)
everything works without error.
The error occurs with the table prov.sql!
View this message in context: http://postgis.17.n6.nabble.com/ERROR-SQL-MM-Spatial-exception-geometry-crosses-an-edge-tp4532494p4532782.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
