[postgis-devel] [PostGIS] #1639: MapAlgebraExpr can't handle conditions
PostGIS trac at osgeo.org
Wed Feb 29 14:24:28 PST 2012
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 When running the example for the one raster version of
 [http://postgis.org/documentation/manual-svn/RT_ST_MapAlgebraExpr.html
 MapAlgebraExpr]:
 UPDATE dummy_rast SET map_rast2 = ST_MapAlgebraExpr(rast,'2BUI','CASE WHEN
 [rast] BETWEEN 100 and 250 THEN 1
 WHEN [rast] = 252 THEN 2
 WHEN [rast] BETWEEN 253 and 254 THEN 3 ELSE 0 END', '0') WHERE rid = 2;
 I don't get the values 1, 2, 3 and 0.
 When I run, as in the example.
 SELECT DISTINCT ST_Value(rast,1,i,j) As origval, ST_Value(map_rast2, 1, i,
 j) As mapval
 FROM dummy_rast CROSS JOIN generate_series(1, 5) AS i CROSS JOIN
 generate_series(1,5) AS j
 WHERE rid = 2;
 I get:
 origval;mapval
 249;
 250;
 251;
 252;
 253;
 254;
 It is beta1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639>
