[postgis-devel] [PostGIS] #1426: OGR2OGR fails importing data to postgis
trac at osgeo.org
Mon Jan 2 09:38:35 PST 2012
Reporter: anguscarr | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: ogr2ogr, import |
Comment(by robe):
Angus,
you had this marked as 1.5, but I assume you are running 2.0? Since there
should be no issue with 1.5 since 1.5 uses a table. Just confirming
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1426#comment:4>
