[postgis-devel] [PostGIS] #1426: OGR2OGR fails importing data to postgis
trac at osgeo.org
Mon Jan 2 12:26:54 PST 2012
Reporter: anguscarr | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: ogr2ogr, import |
Comment(by anguscarr):
Replying to [comment:4 robe]:
> Angus,
> you had this marked as 1.5, but I assume you are running 2.0? Since
there should be no issue with 1.5 since 1.5 uses a table. Just confirming
Yup. Oops.
For what it is worth, backwards compatibility here is more important than
the correctness of code in individual projects.
If nothing else, perhaps this will give me a search term next time it
comes up :-)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1426#comment:5>
