[postgis-devel] [PostGIS] #1427: totopogeom regress failure on 9.1
    trac at osgeo.org
    Mon Jan  2 21:52:50 PST 2012
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 I'm getting:
 ERROR:  column reference "layer_id" is ambiguous at character 323
   I think its the plpgsql you are using with the way they changed the
 checking on what takes precedence in later versions to prevent
 unintentional side-effects.
 See attached
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1427>
