[postgis-devel] Vote on Merging postgis and raster installs andwhen
Bborie Park dustymugs at gmail.com
Tue Jan 3 08:40:50 PST 2012
Oops.  Sorry Chris.  I guess I misunderstood your question.
In my limited understanding of EXTENSIONS, I'd hazard a guess that you
should be able to install a raster extension on top of the postgis
extension without needing to a dump/reload cycle.  Regina would know
best though.
-bborie
On Tue, Jan 3, 2012 at 8:35 AM, Chris Hodgson <chodgson at refractions.net> wrote:
> Thanks bborie, I understand this, but I'm asking more about the constraints
> introduced by the Postgres "extension" mechanism than the actual
> dependencies.
> Chris
> On 12-01-03 08:29 AM, Bborie Park wrote:
>> Yes.  Nothing in geometry and geography depends on or is affected by
>> the raster component.  The raster component does call a few lwgeom
>> functions though.  So, you would not need to do a dump/restore if you
>> were looking to add raster support to an existing PostGIS system.
>> -bborie
>> On Tue, Jan 3, 2012 at 8:23 AM, Chris Hodgson<chodgson at refractions.net>
>>  wrote:
>>> If I (or my packager) compile postgis without raster support, and I
>>> install
>>> it and have data in it, can I add raster support to it later - without
>>> dumping all my data? I think I can with a separate postgis-raster
>>> extension.
>>> Is it possible with everything in one extension? Might be a useful case
>>> to
>>> support... I can see the case for monolithic packaging as well though.
>>> Chris
>>> On 12-01-02 09:06 AM, Paragon Corporation wrote:
>>>> strk,
>>>> I'm fine with raster and topology being dis-abable, but I think the
>>>> default
>>>> should be they are automatically installed and you have to do an
>>>> explicit
>>>> w/out to not get them.  Since topology is in its own
>>>> schema -- it has to be a separate extension.  For raster -- I need to
>>>> know
>>>> if people feel this should stay separated as like I said --
>>>> that means I have to break it back out as its own extension.
>>>> For topology there is no extra dependency (except possibly for it
>>>> needing
>>>> GEOS 3.3 or higher, but like I said I think its pretty stupid we don't
>>>> require GEOS 3.3 for PostGIS 2.0.0 or at least have a glaring wanrning
>>>> you
>>>> need to do a w-out 3.3 to get past). So there really is no excuse for it
>>>> not
>>>> being turned on by default.
>>>> I don't think packagers necessarily leave these things out or use lower
>>>> versions that don't have all features enabled, I think we put them in
>>>> that
>>>> trap
>>>> by not warning them they are missing things. After all they package for
>>>> a
>>>> lot of things not jsut PostGIS and I know as a packager its hard. As a
>>>> PostGIS user things being left out really frustrates me which is one
>>>> reason
>>>> I can see why some windows users are afraid of using Linux.
>>>> Thanks,
>>>> Regina
>>>>> -----Original Message-----
>>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On
>>>>> Behalf Of Paragon Corporation
>>>>> Sent: Monday, January 02, 2012 11:38 AM
>>>>> To: 'PostGIS Development Discussion'
>>>>> Subject: Re: [postgis-devel] Vote on Merging postgis and
>>>>>> I'm not a big fan of monolithic systems.
>>>>> I am -- I hate stuff I can't count on not being there
>>>>> especially if I don't have the ability to compile my own.
>>>>> E.g. it drives me nuts when the packager decides to package
>>>>> an antiquated GEOS and half the things I need are disabled as
>>>>> a result. The same I see with raster.
>>>>>> What's the rationale for forcing anyone who only needs
>>>>> vectors to also
>>>>>> have support for rasters ?
>>>>>  Even for projects I won't really need core raster for, I
>>>>> plan to use it for in the database reporting -- e.g.
>>>>> outputting geometries in my report writer without need for
>>>>> extra mapping software.
>>>>>> Seems more of a packaging issue to me, and I see packagers
>>>>> usually do
>>>>>> more splitting than upstream (breaking packages in -core, -dev,
>>>>>> -utils, -doc, ...)
>>>>> Well - I need to know now.  Because when I had raster as a
>>>>> separate extension, I distinctly remember Paul saying -- "Why
>>>>> don't you have it as part of postgis extension?"
>>>>> So I merged them.  I can't have some postgis 2.0.0 extensions
>>>>> having raster support and some not. Since an extension is
>>>>> more than packaging.  It means -- these are the functions you
>>>>> have -- no pick and choose.  If it is then it has to be a
>>>>> separate extension.
>>>>> For PostGIS 2.0.0 -- raster is a big piece of it.  It would
>>>>> be a shame for people to not get vector support just because
>>>>> their package manager felt they didn't need it.  Trust me
>>>>> there will be some of those and it will be the same annoying
>>>>> issue I have to deal with when I have to compile my own
>>>>> PostGIS  because the packager decided I didn't need all my
>>>>> functions and gave  me a half-assed version of GEOS.
>>>>> Thanks,
>>>>> REgina
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
