[postgis-devel] Raster Regress
Paul Ramsey pramsey at opengeo.org
Tue Jan 3 16:26:52 PST 2012
Kind of a re-run from earlier, but is raster supposed to regress
clean? This is what I get...
 PostgreSQL 9.1.2 on x86_64-apple-darwin10.8.0, compiled by
i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5666) (dot
3), 64-bit
 Postgis 2.0.0SVN - 2012-01-04 00:21:04
   GEOS: 3.2.4-CAPI-1.6.4
   PROJ: Rel. 4.7.1, 23 September 2009
   GDAL: GDAL 1.8.1, released 2011/07/09
Running tests
 check_raster_columns .. ok
 check_raster_overviews .. ok
 rt_io .. ok
 rt_bytea .. ok
 box3d .. ok
 rt_addband .. ok
 rt_band .. ok
 rt_asgdalraster .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_8_diff)
 rt_astiff .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_9_diff)
 rt_asjpeg .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
 rt_aspng .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
 rt_union .. ok
 create_rt_properties_test .. ok
 rt_dimensions .. ok
 rt_scale .. ok
 rt_pixelsize .. ok
 rt_upperleft .. ok
 rt_rotation .. ok
 rt_georeference .. ok
 rt_set_properties .. ok
 drop_rt_properties_test .. ok
 create_rt_empty_raster_test .. ok
 rt_isempty .. ok
 rt_hasnoband .. ok
 drop_rt_empty_raster_test .. ok
 rt_metadata .. ok
 create_rt_band_properties_test .. ok
 rt_band_properties .. ok
 rt_set_band_properties .. ok
 rt_summarystats .. ok
 rt_count .. ok
 rt_histogram .. ok
 rt_quantile .. ok
 rt_valuecount .. ok
 rt_valuepercent .. ok
 rt_bandmetadata .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_36_diff)
 rt_pixelvalue .. ok
 drop_rt_band_properties_test .. ok
 rt_utility .. ok
 create_rt_mapalgebra_test .. ok
 rt_mapalgebraexpr .. ok
 rt_mapalgebrafct .. ok
 rt_mapalgebraexpr_2raster .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_43_diff)
 rt_mapalgebrafct_2raster .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_44_diff)
 drop_rt_mapalgebra_test .. ok
 create_rt_mapalgebrafctngb_test .. ok
 rt_mapalgebrafctngb .. ok
 rt_mapalgebrafctngb_userfunc .. ok
 drop_rt_mapalgebrafctngb_test .. ok
 rt_reclass .. ok
 rt_resample .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_51_diff)
 rt_asraster .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_52_diff)
 rt_intersection .. failed (diff expected obtained:
/var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_53_diff)
 create_rt_gist_test .. ok
 rt_above .. ok
 rt_below .. ok
 rt_contained .. ok
 rt_contain .. ok
 rt_left .. ok
 rt_overabove .. ok
 rt_overbelow .. ok
 rt_overlap .. ok
 rt_overleft .. ok
 rt_overright .. ok
 rt_right .. ok
 rt_same .. ok
 drop_rt_gist_test .. ok
 rt_spatial_relationship .. ok
 rt_intersects .. ok
 rt_samealignment .. ok
 bug_test_car5 .. ok
 uninstall ... failed (Count of object before install (3855) != count
after uninstall (3872))
