[postgis-devel] Raster Regress
dustymugs dustymugs at gmail.com
Tue Jan 3 16:29:46 PST 2012
Paul,
Yes.  Raster is supposed to have zero failures.  I'll fire up and test
my OSX VM when I get the chance.  My OSX VM does use different versions
of GEOS (3.3.1) and GDAL (trunk) though.
-bborie
On 01/03/2012 04:26 PM, Paul Ramsey wrote:
> Kind of a re-run from earlier, but is raster supposed to regress
> clean? This is what I get...
>   PostgreSQL 9.1.2 on x86_64-apple-darwin10.8.0, compiled by
> i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5666) (dot
> 3), 64-bit
>   Postgis 2.0.0SVN - 2012-01-04 00:21:04
>     GEOS: 3.2.4-CAPI-1.6.4
>     PROJ: Rel. 4.7.1, 23 September 2009
>     GDAL: GDAL 1.8.1, released 2011/07/09
> Running tests
>   check_raster_columns .. ok
>   check_raster_overviews .. ok
>   rt_io .. ok
>   rt_bytea .. ok
>   box3d .. ok
>   rt_addband .. ok
>   rt_band .. ok
>   rt_asgdalraster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_8_diff)
>   rt_astiff .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_9_diff)
>   rt_asjpeg .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
>   rt_aspng .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
>   rt_union .. ok
>   create_rt_properties_test .. ok
>   rt_dimensions .. ok
>   rt_scale .. ok
>   rt_pixelsize .. ok
>   rt_upperleft .. ok
>   rt_rotation .. ok
>   rt_georeference .. ok
>   rt_set_properties .. ok
>   drop_rt_properties_test .. ok
>   create_rt_empty_raster_test .. ok
>   rt_isempty .. ok
>   rt_hasnoband .. ok
>   drop_rt_empty_raster_test .. ok
>   rt_metadata .. ok
>   create_rt_band_properties_test .. ok
>   rt_band_properties .. ok
>   rt_set_band_properties .. ok
>   rt_summarystats .. ok
>   rt_count .. ok
>   rt_histogram .. ok
>   rt_quantile .. ok
>   rt_valuecount .. ok
>   rt_valuepercent .. ok
>   rt_bandmetadata .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_36_diff)
>   rt_pixelvalue .. ok
>   drop_rt_band_properties_test .. ok
>   rt_utility .. ok
>   create_rt_mapalgebra_test .. ok
>   rt_mapalgebraexpr .. ok
>   rt_mapalgebrafct .. ok
>   rt_mapalgebraexpr_2raster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_43_diff)
>   rt_mapalgebrafct_2raster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_44_diff)
>   drop_rt_mapalgebra_test .. ok
>   create_rt_mapalgebrafctngb_test .. ok
>   rt_mapalgebrafctngb .. ok
>   rt_mapalgebrafctngb_userfunc .. ok
>   drop_rt_mapalgebrafctngb_test .. ok
>   rt_reclass .. ok
>   rt_resample .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_51_diff)
>   rt_asraster .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_52_diff)
>   rt_intersection .. failed (diff expected obtained:
> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_53_diff)
>   create_rt_gist_test .. ok
>   rt_above .. ok
>   rt_below .. ok
>   rt_contained .. ok
>   rt_contain .. ok
>   rt_left .. ok
>   rt_overabove .. ok
>   rt_overbelow .. ok
>   rt_overlap .. ok
>   rt_overleft .. ok
>   rt_overright .. ok
>   rt_right .. ok
>   rt_same .. ok
>   drop_rt_gist_test .. ok
>   rt_spatial_relationship .. ok
>   rt_intersects .. ok
>   rt_samealignment .. ok
>   bug_test_car5 .. ok
>   uninstall ... failed (Count of object before install (3855) != count
> after uninstall (3872))
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
