[postgis-devel] Raster Regress
Bborie Park
dustymugs at gmail.com
Tue Jan 3 21:53:15 PST 2012
I've run regression tests using the following:
All test boxes have the following in common:
PROJ4 4.7.1
GEOS 3.3.1
GDAL-svn r23698
PostGIS-svn r8668
Slackware Linux 13.37
PostgreSQL 9.1.2 = OK
PostgreSQL 9.0.6 = OK
PostgreSQL 8.4.10 = OK
Slackware64 Linux 13.37
OSX 10.6.8 64-bit
I'll run a series of tests varying the GDAL version though I don't
think that could be causing the regression failures as ST_BandMetadata
and 2-raster ST_MapAlgebra variants do not use GDAL in any way.
-bborie
On Tue, Jan 3, 2012 at 4:29 PM, dustymugs <dustymugs at gmail.com> wrote:
> Paul,
> Yes. Raster is supposed to have zero failures. I'll fire up and test my
> OSX VM when I get the chance. My OSX VM does use different versions of GEOS
> (3.3.1) and GDAL (trunk) though.
> -bborie
> On 01/03/2012 04:26 PM, Paul Ramsey wrote:
>> Kind of a re-run from earlier, but is raster supposed to regress
>> clean? This is what I get...
>> PostgreSQL 9.1.2 on x86_64-apple-darwin10.8.0, compiled by
>> i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5666) (dot
>> 3), 64-bit
>> Postgis 2.0.0SVN - 2012-01-04 00:21:04
>> GEOS: 3.2.4-CAPI-1.6.4
>> PROJ: Rel. 4.7.1, 23 September 2009
>> GDAL: GDAL 1.8.1, released 2011/07/09
>> Running tests
>> check_raster_columns .. ok
>> check_raster_overviews .. ok
>> rt_io .. ok
>> rt_bytea .. ok
>> box3d .. ok
>> rt_addband .. ok
>> rt_band .. ok
>> rt_asgdalraster .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_8_diff)
>> rt_astiff .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_9_diff)
>> rt_asjpeg .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
>> rt_aspng .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
>> rt_union .. ok
>> create_rt_properties_test .. ok
>> rt_dimensions .. ok
>> rt_scale .. ok
>> rt_pixelsize .. ok
>> rt_upperleft .. ok
>> rt_rotation .. ok
>> rt_georeference .. ok
>> rt_set_properties .. ok
>> drop_rt_properties_test .. ok
>> create_rt_empty_raster_test .. ok
>> rt_isempty .. ok
>> rt_hasnoband .. ok
>> drop_rt_empty_raster_test .. ok
>> rt_metadata .. ok
>> create_rt_band_properties_test .. ok
>> rt_band_properties .. ok
>> rt_set_band_properties .. ok
>> rt_summarystats .. ok
>> rt_count .. ok
>> rt_histogram .. ok
>> rt_quantile .. ok
>> rt_valuecount .. ok
>> rt_valuepercent .. ok
>> rt_bandmetadata .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_36_diff)
>> rt_pixelvalue .. ok
>> drop_rt_band_properties_test .. ok
>> rt_utility .. ok
>> create_rt_mapalgebra_test .. ok
>> rt_mapalgebraexpr .. ok
>> rt_mapalgebrafct .. ok
>> rt_mapalgebraexpr_2raster .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_43_diff)
>> rt_mapalgebrafct_2raster .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_44_diff)
>> drop_rt_mapalgebra_test .. ok
>> create_rt_mapalgebrafctngb_test .. ok
>> rt_mapalgebrafctngb .. ok
>> rt_mapalgebrafctngb_userfunc .. ok
>> drop_rt_mapalgebrafctngb_test .. ok
>> rt_reclass .. ok
>> rt_resample .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_51_diff)
>> rt_asraster .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_52_diff)
>> rt_intersection .. failed (diff expected obtained:
>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_53_diff)
>> create_rt_gist_test .. ok
>> rt_above .. ok
>> rt_below .. ok
>> rt_contained .. ok
>> rt_contain .. ok
>> rt_left .. ok
>> rt_overabove .. ok
>> rt_overbelow .. ok
>> rt_overlap .. ok
>> rt_overleft .. ok
>> rt_overright .. ok
>> rt_right .. ok
>> rt_same .. ok
>> drop_rt_gist_test .. ok
>> rt_spatial_relationship .. ok
>> rt_intersects .. ok
>> rt_samealignment .. ok
>> bug_test_car5 .. ok
>> uninstall ... failed (Count of object before install (3855) != count
>> after uninstall (3872))
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
