[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
trac at osgeo.org
Sat Jan 7 20:45:13 PST 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Comment(by robe):
I haven't done the crash dump thing yet. That requires me to test with my
mingw install which I seem to be missing some dependency file for. I
assume its just some dll I forgot to copy.
Anyrate I'm getting a totally different error now and one I have never
seen before.
CONTEXT: PL/pgSQL function "st_asraster" line 26 at RETURN
psql:raster_gardentest_20.sql:16154: ERROR: current transaction is
aborted, com
mands ignored until end of transaction block
psql:raster_gardentest_20.sql:16176: lost synchronization with server: got
messa
ge type "D", length 288025282
When I run the offending line in isolation -- offending query is:
{{{SELECT ST_AsRaster(foo2.the_geom, rast1.rast, '1BB', 1.5, 1.5, false),
ST_AsEWKT(rast1.rast::geometry) As ref1_geom, ST_AsEWKT(foo2.the_geom) As
ref2_geom
FROM (
(SELECT
ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 100, 100, (i-1)*100,
(i-1)*100, 0.0005, -0.0005, 0*i, 0*i), '1BB'), i, (i+1),0),4326) As rast
FROM generate_series(1,10) As i)
) As rast1 CROSS JOIN ((SELECT
ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As the_geom
FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10)
As a) As i(i)
CROSS JOIN generate_series(40,70, 20) As j
ORDER BY i, i*j, j)) As foo2
LIMIT 2;
It generates this error:
ERROR: out of memory
DETAIL: String of 288024126 bytes is too long for encoding conversion.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1066#comment:15>
