[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
trac at osgeo.org
Sat Jan 7 20:47:53 PST 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Forgot this is testing with the latest windows experimental -- r8697,
gdal 9.0.0 rc2
and my sql got mangled in last post
SELECT ST_AsRaster(foo2.the_geom, rast1.rast, '1BB', 1.5, 1.5, false),
ST_AsEWKT(rast1.rast::geometry) As ref1_geom, ST_AsEWKT(foo2.the_geom) As
ref2_geom
FROM (
(SELECT ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 100,
100, (i-1)*100, (i-1)*100, 0.0005, -0.0005, 0*i, 0*i), '1BB'), i,
(i+1),0),4326) As rast
FROM generate_series(1,10) As i)
) As rast1 CROSS JOIN ((SELECT
ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As the_geom
FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As
i(i)
CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, i*j, j)) As
foo2
LIMIT 2;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1066#comment:16>
