#1066: [raster] raster crashes server with arbitrary tests
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Here is a slightly shorter without all that extra fluff that still
generates the same error:
SELECT ST_AsRaster(foo2.the_geom, rast1.rast, '1BB', 1.5, 1.5, false)
FROM (
(SELECT ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 100,
100, (i-1)*100, (i-1)*100, 0.0005, -0.0005, 0*i, 0*i), '1BB'), i,
(i+1),0),4326) As rast
FROM generate_series(1,10) As i)
) As rast1 CROSS JOIN ((SELECT
ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As the_geom
FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As
i(i)
CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, i*j, j)) As
foo2
LIMIT 1;
Let me know if you need me to reduce it down even further.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1066#comment:17>
