[postgis-devel] Extensions
Paragon Corporation
lr at pcorp.us
Tue Jan 10 16:18:48 PST 2012
> There are no upgrade scripts for that version number. If you set the
Version.config to 2.0.0a18 you'll see upgrade scripts generated.
I changed the version config to 2.0.0a18, but it doesn't install an upgrade
script.
However I do see in the sql folder that it generates this file:
postgis--2.0.0a{17..1}--2.0.0a18.sql
Is that a special extension file format I'm not familiar with to worf for
a1-a17?
Thanks,
Regina
