[postgis-devel] Extensions
Paul Ramsey
pramsey at opengeo.org
Tue Jan 10 18:28:14 PST 2012
Perhaps the bash syntax was too new... I've tried another variant.
P.
On Tue, Jan 10, 2012 at 4:18 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> There are no upgrade scripts for that version number. If you set the
> Version.config to 2.0.0a18 you'll see upgrade scripts generated.
> I changed the version config to 2.0.0a18, but it doesn't install an upgrade
> script.
> However I do see in the sql folder that it generates this file:
> postgis--2.0.0a{17..1}--2.0.0a18.sql
> Is that a special extension file format I'm not familiar with to worf for
> a1-a17?
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
