[postgis-devel] [PostGIS] #393: shp2pgsql returns "fseek(-xxx) failed on DBF file." for large (>2GB) DBF files
PostGIS trac at osgeo.org
Thu Jan 19 14:39:32 PST 2012
files
 Reporter:  maximeguillaud                     |       Owner:  pramsey
     Type:  defect                             |      Status:  new
 Priority:  medium                             |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper                      |     Version:  1.5.X
 Keywords:  shp2pgsql fseek failed large file  |
Comment(by dfuhry2):
 Regarding previous patches, changing "int" to "long" has no effect on
 Linux at least, since both are 4 bytes with a 32-bit OS and 8 bytes with a
 64-bit OS. One can write a simple C program to printf("sizeof(int): %d,
 sizeof(long): %d\n", sizeof(int), sizeof(long)) to verify.
 My attached 6-line large_dbf.v1.patch fixes my problems writing > 2GB DBF
 files with shp2pgsql on 32-bit Linux.
 1. Add -D_FILE_OFFSET_BITS=64 to Makefile's CFLAGS, which makes off_t an
 unsigned 8 byte integer (equivalent to unsigned long long type).
 2. In shapefil.h, change typedef of SAOffset from unsigned long (which is
 4-byte on 32-bit systems) to off_t.
 3. In safileio.c, change fseek call to fseeko, and cast offset to off_t
 rather than long. fseek always takes a long, and a long can't be made 8
 bytes on a 32-bit system.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/393#comment:10>
