[postgis-devel] [PostGIS] #393: shp2pgsql returns "fseek(-xxx) failed on DBF file." for large (>2GB) DBF files
trac at osgeo.org
Fri Jan 20 06:01:40 PST 2012
files
Reporter: maximeguillaud | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: loader/dumper | Version: 1.5.X
Keywords: shp2pgsql fseek failed large file |
Comment(by gdt):
Please keep in mind that _FILE_OFFSET_BITS is nonportable; it isn't used
on BSDs, where off_t is simply always int64_t. But using off_t and lseeko
instead of long seems entirely sensible. So probably the
-D_FILE_OFFSET_BITS=64 needs to be wrapped in a configure test to be added
only on operating systems where it makes sense.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/393#comment:11>
