[postgis-devel] ST_Value performance
Sandro Santilli
strk at keybit.net
Tue Jan 31 10:26:54 PST 2012
I'm willing to dump the contents of a raster
to a table to get:
x,y,point,value1,value2,valueN
Thats for an N band raster.
After first using ST_PixelAsPolygon call, which was relatively fast
I ended up with 206893 rows in a new table, one per pixel.
Now I'm running an update adding the value to each of those rows,
using ST_Value. I do understand that over 200k calls are a lot to
do, but fetching a value itself shouldn't take long, right ?
It's a 661x313 pixels raster.
Well... it's been running at 100% CPU for a good amount of time now.
The query:
=# update chenyx06a_pixels set shift_lat = ST_Value(o.rast, 1, st_centroid) from chenyx06a o;
The time it is taking:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
11518 postgres 20 0 309m 51m 42m R 100 1.3 36:55.82 postgres
That's almost 40 minutes with CPU at 100%.
Is it expected ?
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
