[postgis-devel] ST_Value performance
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Jan 31 11:07:31 PST 2012
Could you tell us more about your general goal. Seems to be a case for ST_MapAlgebra...
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Sandro Santilli
> Sent: Tuesday, January 31, 2012 1:27 PM
> To: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] ST_Value performance
> I'm willing to dump the contents of a raster to a table to get:
> x,y,point,value1,value2,valueN
> Thats for an N band raster.
> After first using ST_PixelAsPolygon call, which was relatively fast I ended up with
> 206893 rows in a new table, one per pixel.
> Now I'm running an update adding the value to each of those rows, using
> ST_Value. I do understand that over 200k calls are a lot to do, but fetching a
> value itself shouldn't take long, right ?
> It's a 661x313 pixels raster.
> Well... it's been running at 100% CPU for a good amount of time now.
> The query:
> =# update chenyx06a_pixels set shift_lat = ST_Value(o.rast, 1, st_centroid) from
> chenyx06a o;
> The time it is taking:
> PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
> 11518 postgres 20 0 309m 51m 42m R 100 1.3 36:55.82 postgres
> That's almost 40 minutes with CPU at 100%.
> Is it expected ?
> --strk;
> ,------o-.
> | __/ | Thank you for PostGIS-2.0 Topology !
> | / 2.0 | http://www.pledgebank.com/postgistopology
> `-o------'
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
