[postgis-devel] [PostGIS] #1933: [raster] raster2psql command installed into /usr
trac at osgeo.org
Wed Jul 25 15:21:09 PDT 2012
Reporter: kib | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by mcayland):
The standard convention on a UNIX-based OS is that executables installed
as part of a distribution via package management are installed in /usr,
whereas self-built executables are installed in /usr/local. Hence it's
possible to determine what has been supplied by the distribution and what
has been built locally.
Is the problem that raster2pgsql is being installed as both
/usr/raster2pgsql and /usr/bin/raster2pgsql? That could suggest that
PREFIX is not being set somewhere either in the build or as part of the
regression tests.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1933#comment:4>
