[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
trac at osgeo.org
Thu Jun 7 08:50:34 PDT 2012
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
Line 954 of topology/sql/populate.sql contains a comment about code that
seems to be there specifically to handle this case, just evidently in the
wrong way (ST_MakeValid doesn't clean non-simple lines)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:5>
