[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Thu Jun 7 16:42:39 PDT 2012
polygons
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 That line was there to fix #1650. In that case the snapping made the line
 collapse to a point. In this one it's still a line but non-simple. Will
 need to add the new testcase into
 topology/test/regress/topogeo_addlinestring.sql and then fix...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:6>
