[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
PostGIS trac at osgeo.org
Mon Jun 11 05:14:52 PDT 2012
 Reporter:  jomarlla               |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 strk I don't understand your question.  extensions use the generated
 comments and massages the other generated files to add ALTER EXTENSION and
 remove things not legal for extensions (like removing the BEGIN / END
 TRANSACTION) since create extension always runs in its own transaction.
 So regular install should install comments files if it creates them or
 they are available (e.g as should be the case when installing from tar
 ball).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1779#comment:2>
