[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
trac at osgeo.org
Mon Jun 11 09:55:10 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by strk):
Robe, the question was: what do you expect to see in the share folder
after make install ?
I think I can answer myself: everything is "duplicated" in share folder
and in extension folder. It is still weird to require comments when
building againts 9.1 but not when building against previous postgresql
versions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:3>
