[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
trac at osgeo.org
Mon Jun 11 13:40:47 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
comments should be auto packaged with tar ball and should always be
installed if building from tar ball. So the only reason one should need
to build it is if they are building from svn. I'd be fine with always
requiring it for SVN builds, but others might have issues with the
xsltproc requirement.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:6>
