[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
trac at osgeo.org
Tue Jun 12 00:32:39 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Comment(by strk):
It will not be required by r9885, r9886 and r9887 -- those commits only
build and install them IFF xsltproc was found. Anyway, I'll double-check.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:7>
