[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
PostGIS trac at osgeo.org
Tue Jun 12 00:57:48 PDT 2012
  Reporter:  jomarlla               |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Comment(by strk):
 Ah, now I see what you mean. If someone fetches a tarball she will have
 the comments but they won't be installed unless XSLTPROC is found.
 r9888 in branch fixes this, always installing comments IF they are
 available.
 r9889 in trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:8>
