[postgis-devel] [PostGIS] #1830: pgsql2shp fix for "XInvalid endian flag value encountered"
PostGIS trac at osgeo.org
Tue Jun 19 14:59:38 PDT 2012
  Reporter:  dfuhry2        |       Owner:  mcayland
      Type:  defect         |      Status:  new
  Priority:  medium         |   Milestone:  PostGIS 2.0.2
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:                 |    Keywords:
Comment(by mcayland):
 Possibly the only sensible way to do this would be to have another command
 line option to force this setting where required, however because using
 older libpq is not a generally supported setup on PostgreSQL and we're not
 going to support 8.4 when 2.1 comes out anyway then I'm tempted to set
 this to 'wontfix'.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1830#comment:13>
