[postgis-devel] [PostGIS] #1830: pgsql2shp fix for "XInvalid endian flag value encountered"
PostGIS trac at osgeo.org
Tue Jun 19 20:16:46 PDT 2012
  Reporter:  dfuhry2        |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.2
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  wontfix        |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 +1 - yes let's not fix.
 I think the newer libpqs are already smart enough to work with older
 PostgreSQL.  So it's only an issue for those trying to use an older libpq
 with a newer postgreSQL install.  They shouldn't be doing that anyway and
 we shouldn't be encouraging it.  Even PostgreSQL for example doesn't allow
 you to backup/restore a PostgreSQL database with an older
 pg_dump/pg_restore.  I see this as much the same thing :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1830#comment:14>
