[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Thu Jun 21 13:09:30 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by mcayland):
One of the delays on this is that my dev environment is set up for 9.0 and
so WITH... INSERT doesn't work. I've used the following as a substitute:
CREATE OR REPLACE FUNCTION create1828() RETURNS text AS $$
DECLARE
cnt int;
x float;
BEGIN
FOR x IN SELECT generate_series(1, 20000)::float / 1000 LOOP
-- RAISE NOTICE 'x is %', x;
INSERT INTO _test_pos(pos) SELECT ST_MakePoint(x,
x)::geography;
END LOOP;
RETURN 'done';
END;
$$ LANGUAGE 'plpgsql';
Now I have the actual sample data, I'll have a poke around and see if I
can figure out what is happening.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:23>
