[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
Sandro Santilli
strk at keybit.net
Thu Jun 21 13:55:30 PDT 2012
> for ST_DWithin
> Reporter: realityexists | Owner: mcayland
> Type: defect | Status: new
> Priority: medium | Milestone: PostGIS 2.0.2
> Component: postgis | Version: 2.0.x
> Keywords: |
> Comment(by mcayland):
> One of the delays on this is that my dev environment is set up for 9.0 and
> so WITH... INSERT doesn't work. I've used the following as a substitute:
FYI, all you need is to put the INSERT first:
INSERT INTO xxx WITH ...
--strk(on 8.4);
