[postgis-devel] Resigning from the PSC
Paragon Corporation
lr at pcorp.us
Thu Jun 21 14:15:38 PDT 2012
I see Jenkins has a windows installer. I'll try to take a stab at setting
up a windows build one in the coming weeks to automate some of the windows
testing and hopefully automate the windows builds.
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Chris Hodgson
> Sent: Thursday, June 21, 2012 5:00 PM
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] Resigning from the PSC
> Most of what hudson does is configured from within hudson
> itself, if you login at http://office.refractions.net:1500
> you can possibly look at the configuration of the build
> tasks. Let me know if you don't know your account info there
> (Kevin set it up way back).
> In addition to the hudson configuration (there are some
> longish shell scripts that live within the hudson config),
> there are a couple of shell scripts in a secondary repository
> that help with the builds - they are specific to the way that
> Kevin setup the builds and tests on the hudson box - all of
> the various versions of the pre-requisiste libraries are
> installed and there are several postgres databases setup and
> then some LD library magic is used to get a specific
> collection of pieces to work together to do a test.
> If someone else is looking at setting up hudson, it may be
> worth noting that the project has forked and a large portion
> of the development "community" went to the forked "jenkins",
> while Oracle continues to develop "hudson". I think I'd tend
> to go with Jenkins if I were setting it up again today.
> Chris
> On 12-06-21 12:52 PM, Paragon Corporation wrote:
> >> Whatever alternative the project moves to, it will be
> easier for me
> >> to help with the transition if it happens before July 6th. The
> >> current hudson server won't cease to exist at that time,
> but it will
> >> be in an essentially unsupported, unmaintained state.
> > Chris -- if you can send us the hudson scripts that would be super.
> > Never seen one before so not sure what is entailed.
> >> It's been fun, I wish you all the best.
> > Yes indeed it's been fun Chris. Don't stay a stranger.
> > Very sorry to see you go :(
> > Thanks,
> > Regina
> > postgis-devel mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
