[postgis-devel] [PostGIS] #1641: TopoGeo_addLineString: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Mon Mar 5 06:56:32 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Comment(by strk):
 Did you use the _same_ tolerance value ?
 CreateTopology:
 [[Image(CreateTopologyTolerance.png)]]
 toTopoGeom:
 [[Image(toTopoGeomTolerance.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1641#comment:19>
