[postgis-devel] [PostGIS] #1641: TopoGeo_addLineString: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Mon Mar 5 06:59:03 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Comment(by lrssvt):
 Replying to [comment:19 strk]:
 > Did you use the _same_ tolerance value ?
 Yes, i did use 0.001!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:20>
