[postgis-devel] PostGIS 2.0.0beta2 working for me...
Salvatore Larosa
lrssvtml at gmail.com
Sun Mar 11 12:29:33 PDT 2012
Now it's OK!
I simply added:
$ LD_LIBRARY_PATH=/usr/local/pgsql/lib/ make check
Only now I understand the meaning of:
"...or be prepared to deal with the impending headaches."
in Testing paragraph!! :-))
All the best!
-SL
Il giorno dom, 11/03/2012 alle 20.03 +0100, Salvatore Larosa ha scritto:
> Hi,
> in dumper.err:
> could not connect to server: No such file or directory
> Is the server running locally and accepting
> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
> while, in loader.err:
> SET
> SET
> BEGIN
> psql:/tmp/pgis_reg/loader.out:5: NOTICE: CREATE TABLE will create
> implicit sequence "loadedshp_gid_seq" for serial column "loadedshp.gid"
> CREATE TABLE
> psql:/tmp/pgis_reg/loader.out:6: NOTICE: ALTER TABLE / ADD PRIMARY KEY
> will create implicit index "loadedshp_pkey" for table "loadedshp"
> ALTER TABLE
> INSERT 0 1
> COMMIT
> Why can not I connect to the server?
> Il giorno dom, 11/03/2012 alle 11.18 -0700, Bborie Park ha scritto:
> > Salvatore,
> > Can you attach /tmp/pgis_reg/dumper.err and /tmp/pgis_reg/loader.err
> > in a response to this email thread?
> > -bborie
> > On Sun, Mar 11, 2012 at 3:23 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> > > Unfortunately, I can't tell the same!
> > > Only topology and raster regression tests is right for me!
> > > In core I get 20 error:
> > > PostgreSQL 9.1.2 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
> > > 4.6.2-12) 4.6.2, 64-bit
> > > Postgis 2.0.0beta3SVN - r9475 - 2012-03-09 20:31:33
> > > GEOS: 3.3.2-CAPI-1.7.2
> > > PROJ: Rel. 4.7.1, 23 September 2009
> > > Running tests
> > > loader/Point ........ failed (dumper geog test: dumping loaded
> > > table: /tmp/pgis_reg/dumper.err)
> > > loader/PointM ... failed ( wkt test: running shp2pgsql
> > > output: /tmp/pgis_reg/loader.err)
> > > loader/PointZ ... failed ( wkt test: running shp2pgsql
> > > loader/MultiPoint ... failed ( wkt test: running shp2pgsql
> > > loader/MultiPointM ... failed ( wkt test: running shp2pgsql
> > > loader/MultiPointZ ... failed ( wkt test: running shp2pgsql
> > > loader/Arc ... failed ( wkt test: running shp2pgsql
> > > loader/ArcM ... failed ( wkt test: running shp2pgsql
> > > loader/ArcZ ... failed ( wkt test: running shp2pgsql
> > > loader/Polygon ... failed ( wkt test: running shp2pgsql
> > > loader/PolygonM ... failed ( wkt test: running shp2pgsql
> > > loader/PolygonZ ... failed ( wkt test: running shp2pgsql
> > > loader/TSTPolygon ... failed ( wkt test: running shp2pgsql
> > > loader/TSIPolygon ... failed ( wkt test: running shp2pgsql
> > > loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql
> > > loader/PointWithSchema ..... ok
> > > loader/NoTransPoint ........ failed (dumper wkb test: dumping loaded
> > > loader/NotReallyMultiPoint ... failed ( wkt test: running shp2pgsql
> > > loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
> > > loader/ReprojectPts .... failed ( wkt test: running shp2pgsql
> > > loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql
> > > loader/Latin1 .... ok
> > > binary .. ok
> > > regress .. ok
> > > regress_index .. ok
> > > regress_index_nulls .. ok
> > > lwgeom_regress .. ok
> > > regress_lrs .. ok
> > > removepoint .. ok
> > > setpoint .. ok
> > > simplify .. ok
> > > snaptogrid .. ok
> > > summary .. ok
> > > affine .. ok
> > > empty .. ok
> > > measures .. ok
> > > legacy .. ok
> > > long_xact .. ok
> > > ctors .. ok
> > > sql-mm-serialize .. ok
> > > sql-mm-circularstring .. ok
> > > sql-mm-compoundcurve .. ok
> > > sql-mm-curvepoly .. ok
> > > sql-mm-general .. ok
> > > sql-mm-multicurve .. ok
> > > sql-mm-multisurface .. ok
> > > polyhedralsurface .. ok
> > > polygonize .. ok
> > > postgis_type_name .. ok
> > > out_geometry .. ok
> > > out_geography .. ok
> > > in_gml .. ok
> > > in_kml .. ok
> > > iscollection .. ok
> > > regress_ogc .. ok
> > > regress_ogc_cover .. ok
> > > regress_ogc_prep .. ok
> > > regress_bdpoly .. ok
> > > regress_proj .. ok
> > > regress_management .. ok
> > > dump .. ok
> > > dumppoints .. ok
> > > wmsservers .. ok
> > > wkt .. ok
> > > wkb .. ok
> > > tickets .. ok
> > > typmod .. ok
> > > remove_repeated_points .. ok
> > > split .. ok
> > > relate .. ok
> > > bestsrid .. ok
> > > concave_hull .. ok
> > > hausdorff .. ok
> > > regress_buffer_params .. ok
> > > offsetcurve .. ok
> > > relatematch .. ok
> > > isvaliddetail .. ok
> > > sharedpaths .. ok
> > > snap .. ok
> > > node .. ok
> > > unaryunion .. ok
> > > clean .. ok
> > > relate_bnr .. ok
> > > uninstall .. ok (3855)
> > > Run tests: 84
> > > Failed: 20
> > > make[1]: *** [check] Error 20
> > > make[1]: Leaving directory `/home/sam/pacchetti_gis/postgis-svn/regress'
> > > make: *** [check] Error 1
> > > Il giorno sab, 10/03/2012 alle 17.01 -0800, pcreso at pcreso.com ha
> > > scritto:
> > >> FWIW:
> > >> Built & installed OK on OpenSuse 12.1 64 bit:
> > >> PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE
> > >> Linux) 4.6.2, 64-bit
> > >> Postgis 2.0.0beta2 - r9428 - 2012-03-10 23:59:03
> > >> Passed all regression tests (make check) for core, raster & topology:
> > >> Works OK with imposm for OSM server:
> > >> imposm --read --write --optimize -d osm --overwrite-cache
> > >> newzealand.osm
> > >> General queries (so far) work OK.
> > >> Brent Wood
> > >> --- On Thu, 3/8/12, Paul Ramsey <pramsey at opengeo.org> wrote:
> > >> From: Paul Ramsey <pramsey at opengeo.org>
> > >> Subject: [postgis-devel] PostGIS 2.0.0beta2
> > >> To: "PostGIS Users Discussion"
> > >> <postgis-users at postgis.refractions.net>,
> > >> postgis-devel at postgis.refractions.net
> > >> Date: Thursday, March 8, 2012, 10:06 AM
> > >> Hi All,
> > >> PostGIS 2.0.0beta2:
> > >> http://postgis.org/download/postgis-2.0.0beta2.tar.gz
> > >> Current open tickets: http://trac.osgeo.org/postgis/report/22
> > >> You'll note that the number of open tickets is getting close
> > >> to zero.
> > >> Like a rocket ship countdown, when we get to zero, we launch.
> > >> But we need your help now, more than ever. Please try out
> > >> PostGIS 2.0.
> > >> Download it, build it, move your databases to it, make sure it
> > >> works
> > >> for you.
> > >> Thanks!!!
> > >> _______________________________________________
> > >> postgis-devel mailing list
> > >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
