[postgis-devel] Problem buiding on Windows
Paul Ramsey pramsey at opengeo.org
Tue Mar 13 14:03:24 PDT 2012
I build with MinGW 32, as pulled from here
http://sourceforge.net/projects/mingw/files/Installer/
my directions are here
http://trac.osgeo.org/postgis/wiki/DevWikiWinMingWSys_20_MSVC
P.
On Tue, Mar 13, 2012 at 2:00 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> But I just checked out everything from scratch...
> Anything else has to be updated? You build with MinGW-w64 right?
> Anybody tried recently with the MinGW 3.4.5?
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>> Sent: Tuesday, March 13, 2012 4:54 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] Problem buiding on Windows
>> Seems like. It looks very much like liblwgeom.h has not been regenerated from
>> liblwgeom.h.in in some time.
>> P.
>> On Tue, Mar 13, 2012 at 1:49 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
>> wrote:
>> > Am I the only one having this problem building on Windows 7 with the old
>> MinGW 3.4.5?
>> > gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
>> > -Wdeclaration-after-statement -Wendif-labels -Wformat-security
>> > -fno-strict-aliasing -fwra pv  -I/c/projects/geos/rel-3.3.2/include
>> > -I/c/projects/pg/pg90/include
>> > -I/c/projects/libxml/libxml2-2.7.8release/include/libxml2 -I../liblw
>> > geom -I../libpgcommon -I. -I.
>> > -Ic:/projects/pg/pg90/include/POSTGR~1/server
>> > -Ic:/projects/pg/pg90/include/POSTGR~1/internal -I./src/include/
>> > port/win32 -DEXEC_BACKEND
>> > "-Ic:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../src/includ
>> > e/port/win32" -Ic:/projects/pg/pg90/include
>> > /POSTGR~1/server/port/win32  -c -o lwgeom_box3d.o lwgeom_box3d.c
>> > lwgeom_box3d.c: In function `BOX3D_in':
>> > lwgeom_box3d.c:104: error: structure has no member named `srid'
>> > lwgeom_box3d.c: In function `BOX3D_to_LWGEOM':
>> > lwgeom_box3d.c:246: error: structure has no member named `srid'
>> > lwgeom_box3d.c: In function `LWGEOM_to_BOX3D':
>> > lwgeom_box3d.c:296: error: structure has no member named `srid'
>> > lwgeom_box3d.c: In function `BOX3D_combine':
>> > lwgeom_box3d.c:396: error: structure has no member named `srid'
>> > lwgeom_box3d.c:407: error: structure has no member named `srid'
>> > lwgeom_box3d.c: In function `BOX3D_construct':
>> > lwgeom_box3d.c:445: error: structure has no member named `srid'
>> > make[1]: *** [lwgeom_box3d.o] Error 1
>> > make[1]: Leaving directory `/c/projects/postgis/postgis'
>> > make: *** [all] Error 1
>> > Thanks,
>> > Pierre
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
