[postgis-devel] Problem buiding on Windows
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Mar 13 14:04:44 PDT 2012
Ok. Got it. I had to erase liblwgeom.h Seems like the dependencies do not work very well.
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Tuesday, March 13, 2012 5:03 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Problem buiding on Windows
> I build with MinGW 32, as pulled from here
> http://sourceforge.net/projects/mingw/files/Installer/
> my directions are here
> http://trac.osgeo.org/postgis/wiki/DevWikiWinMingWSys_20_MSVC
> P.
> On Tue, Mar 13, 2012 at 2:00 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> > But I just checked out everything from scratch...
> > Anything else has to be updated? You build with MinGW-w64 right?
> > Anybody tried recently with the MinGW 3.4.5?
> > Pierre
> >> [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
> >> Paul Ramsey
> >> Sent: Tuesday, March 13, 2012 4:54 PM
> >> Seems like. It looks very much like liblwgeom.h has not been
> >> regenerated from liblwgeom.h.in in some time.
> >> P.
> >> On Tue, Mar 13, 2012 at 1:49 PM, Pierre Racine
> >> wrote:
> >> > Am I the only one having this problem building on Windows 7 with
> >> > the old
> >> MinGW 3.4.5?
> >> > gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
> >> > -Wdeclaration-after-statement -Wendif-labels -Wformat-security
> >> > -fno-strict-aliasing -fwra pv -I/c/projects/geos/rel-3.3.2/include
> >> > -I/c/projects/pg/pg90/include
> >> > -I/c/projects/libxml/libxml2-2.7.8release/include/libxml2
> >> > -I../liblw geom -I../libpgcommon -I. -I.
> >> > -Ic:/projects/pg/pg90/include/POSTGR~1/server
> >> > -Ic:/projects/pg/pg90/include/POSTGR~1/internal -I./src/include/
> >> > port/win32 -DEXEC_BACKEND
> >> > "-Ic:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../src/inc
> >> > lud e/port/win32" -Ic:/projects/pg/pg90/include
> >> > /POSTGR~1/server/port/win32 -c -o lwgeom_box3d.o lwgeom_box3d.c
> >> > lwgeom_box3d.c: In function `BOX3D_in':
> >> > lwgeom_box3d.c:104: error: structure has no member named `srid'
> >> > lwgeom_box3d.c: In function `BOX3D_to_LWGEOM':
> >> > lwgeom_box3d.c:246: error: structure has no member named `srid'
> >> > lwgeom_box3d.c: In function `LWGEOM_to_BOX3D':
> >> > lwgeom_box3d.c:296: error: structure has no member named `srid'
> >> > lwgeom_box3d.c: In function `BOX3D_combine':
> >> > lwgeom_box3d.c:396: error: structure has no member named `srid'
> >> > lwgeom_box3d.c:407: error: structure has no member named `srid'
> >> > lwgeom_box3d.c: In function `BOX3D_construct':
> >> > lwgeom_box3d.c:445: error: structure has no member named `srid'
> >> > make[1]: *** [lwgeom_box3d.o] Error 1
> >> > make[1]: Leaving directory `/c/projects/postgis/postgis'
> >> > make: *** [all] Error 1
> >> > Thanks,
> >> > Pierre
> >> > _______________________________________________
> >> > postgis-devel mailing list
> >> > postgis-devel at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
