[postgis-devel] [PostGIS] #1693: No uninstall script for legacy_minimal.sql
PostGIS trac at osgeo.org
Fri Mar 16 11:04:16 PDT 2012
 Reporter:  Sharpie                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  low                    |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Testing with SVN r9513.
 After loading `legacy_minimal.sql` into a database, `uninstall_legacy.sql`
 will fail due to missing items.
 Current workaround is to layer on a full install of `legacy.sql` and then
 peel everything off with `uninstall_legacy.sql`.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1693>
