[postgis-devel] [PostGIS] #1693: No uninstall script for legacy_minimal.sql
trac at osgeo.org
Thu Mar 22 04:46:35 PDT 2012
Reporter: Sharpie | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
I don't think we need an uninstall script for legacy_minimal. We just
need to fix the uninstall_legacy.sql script.
The issue I see with the generated uninstall is that it is putting in
DROP AGGREGATE
instead of
DROP AGGREGATE IF EXISTS
If I change all those to DROP AGGREGATE IF EXISTS -- works fine even on a
database with no legacy functions.
It seems this script is now autogenerated so I don't know how to fix it.
strk -- can you please change your generator.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1693#comment:1>
