[postgis-devel] [PostGIS] #1704: Change uninstall generators do DROP AGGREGATE IF EXISTS
trac at osgeo.org
Thu Mar 22 05:01:28 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
DROP AGGREGATE IF EXISTS has existed since PostgreSQL 8.2, so there is no
reason not to use it.
As noted in #1693, changing the uninstall to DROP AGGREGATE IF EXISTS will
make uninstall_legacy work for both legacy and legacy_minimal. It will
help for the other uninstall scripts as well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1704>
