[postgis-devel] [PostGIS] #1704: Change uninstall generators do DROP AGGREGATE IF EXISTS
PostGIS trac at osgeo.org
Mon Mar 26 19:10:20 PDT 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 fixed at r9550  now the uninstall_legacy should work to uninstall any
 legacy you've got even if minimal.
 I also put in a drop view if exists.  I think there are some others that
 should be done that way too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1704#comment:1>
