[postgis-devel] [PostGIS] #1698: Review polygon collapse policy in ST_Simplify
trac at osgeo.org
Thu Mar 22 09:49:01 PDT 2012
Reporter: strk | Owner: strk
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by strk):
Ok, the whole point of ST_Simplify was (as originally developed) to reduce
vectors for sending to clients for rendering. True, a 3-points ring is
invalid as is the single-point one.
But they can still have an use ! For example you can _see_ something
rendered (modulo rendering limitations as in mapnik/AGG case:
https://github.com/mapnik/mapnik/issues/1140) and you know _where_ the
feature is located (if you want to zoom to it, which may send more
vectors, less simplified, etc).
The other thing is that you can always strip non-valids later. We know we
may be introducing non-valids so why having 1-class invalids that we drop
lightly and 2-class invalids which we don't drop (complex self-
intersections).
I've to say that I'm tempted to revert this to really keep a single vertex
rather than 3 vertices, but knowing that AGG won't render them makes me
belive we're doing a better service returning at least 3 points than 1.
For all AGG users (mapserver,mapnik,what else?).
I'm attaching 2 images of mapnik rendering a set of ~8k simplified
polygons representing italian municipalities. The version you don't see
much is the one with 1-vertex polygons, the other is with 3-vertex
polygons. You can see you can recognize the country by only the collapsed
versions of polygons rendered.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1698#comment:6>
