[postgis-devel] [PostGIS] #1698: Review polygon collapse policy in ST_Simplify
PostGIS trac at osgeo.org
Thu Mar 22 09:56:47 PDT 2012
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by strk):
 Sorry but the polygon boundaries are rendered in white, so you'll need a
 good reader to see them (it's white on transparent). Se the difference
 between before and after the patch is between knowing the shape and extent
 of italy and not knowing it.
 Forget style-snap-simpNCD.png which is not directly related.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1698#comment:7>
